rcslon
Поисковая система ROCKWELL lBeacon
271 posts in this topic
Не могу подрубиться в проге Блютуз ГПС к маяку, делаю по инструкции, предварительно сопрягаю ПУ с телефоном, выбираю в проге мой маяк (имя как и было при сопряжении), ставлю галку Enable Mock GPS Provider, нажимаю Connect, прога пишет "Cannot to enable mock provider - Allow Mock Location Settings..". Было такое у кого нибудь?
Так, и вы разрешили подмену данных на уровне системы? И что тогда прога пишет?
Господа, кто английским владеет, почитайте этот мой мануал - что где неверно я перевел, что поправить?
Radio search system Rockwell lBeacon designed to search for people, animals, machinery or materials, which were be pre-installed beacons of this system. Very long range - up to 8 km* , and long time work beacon - up to 2 years good distinguish the search system from other similar products. To work Rockwell lBeacon system does not require a cellular, SIM cards, payed service and so on. You may using the beacons: on the ground as well as underground parking lots, garages, shopping malls, basements and attics, ie there any GPS trackers do not work.
If necessary, you can observe the position of the beacon (or beacons to 5 simultaneously), their speed and altitude in real time on a map on the screen of the smartphone or tablet on Android. (Of course, if you connect GPS receiver to beacon Mini or Sens)
Beacon Sens has a built-in accelerometer, you can use it for the anti-theft protection of various objects. When you move the beacon in the search device sounds an alarm.
Principle searching  beacon, who mounted on the subject (collar, clothing) is to assess the level of radio signal (in percent) observed on the display on the  search device.
Radio search system Rockwell lBeacon is may be equipped with various types of beacons (LongLife, Light, Mini and Sens), the differences you see in the table and below:
Beacon Sens Mini Long Life Light.
Search beacon from searcher device Yes Yes Yes Yes
Work with "repeater" mode Yes Yes Yes Yes
"Alarm" mode with motion sensor Yes - - -
The ability to connect the GPS receiver Yes Yes - -
Continuous operation Up to 2 month Up to 2 month Up to 2 year N/A
Type of battery Built-in rechargeable battery by miniUSB Built-in rechargeable battery by miniUSB Alcaline battery 2* ААА External 3-12 volt
Weight 12  gr. 12  gr. 21 gr(without batteries). 3 gr.
Dimension 43 * 22 * 8 mm 43 * 22 * 8 mm 64 * 35 * 15 mm 25 * 20 * 5 mm
Beacon Sens - covered with a flexible plastic to reduce weight and bulk. Equipped with a built-in motion sensor and can work in "Alarm" mode. Has an input for an external GPS - receiver, from which receives the coordinates.
Beacon Mini - same what Sens, but without motion sensor
Beacon Long Life - in a hard plastic case, . Is powered by 2 x AAA alcaline batteries, life of battery life for up to 2 years. Battery NOT included!
Beacon Light - very small size and weight, external power.
The main functions of the system:
- Search beacons at a distance up to 8 km*  with the help by monitoring the signal strength of the beacon on the digital display searcher. (in percentage from 0 to 100)
- Duration of continuous operation with long-range and power-efficient digital beacons:
lBeacon LongLife - up to 2 years from 2 AAA batteries
lBeacon Mini and Sens - up to 2 months on internal battery,
- View the last known coordinates of the beacon on the digital display searcher, when you connect an external GPS receiver to the beacon Mini or Sens .
- Compatible with NAZA Lite, NAZA M v1, NAZA M v2 and PHANTOM 2 - easy connection beacons Mini and Sens to quadrocopter for search, observation coordinates and flight parameters (speed, altitude, etc.) in real time (only beacons lBeacon Mini and Sens).
- Automatic recognition of the connected GPS receiver and baud rate (only beacons lBeacon Mini and Sens).
- Beacon lBeacon Mini and Sens have built-in LiPo battery, charging from computer USB port (connector mimiUSB) or anothe external charger. The charging indicator .
- Improved whip antenna may be determine the direction of the beacon (only in the absence of reflected signals). If necessary, to the search appliance can connect directional antenna (not included in delivery), with increases in the range of 2.5 - 3.5 times.
- Transfer the coordinates of the beacon in real time on a computer or smartphone via Bluetooth device search for observation on the map (imitation wireless GPS receiver, protocol NMEA 0183) (only beacons lBeacon Mini and Sens with external GPS receiver)
- Indication of battery voltage beacons and the searcher on the display.
- To the beacon Sens - "Alarm" mode with motion sensor. Filing alarms  searcher when moving or tilting the RFbeacon. Automatic control of communication.
- Built-in LiPo battery to the  searcher, charging from computer USB port (connector mimiUSB). Charging indicator.
- Display on the map on the screen of a smartphone position to 5 beacons simultaneously (including their current data - height, speed, heading). Via a special program. (only beacons lBeacon Mini and Sens)
- Management of the search appliance with the Android smartphone or Android tablet. Changing setting the beacon(for advanced users). Via a special program.
-You can use one of the beacon as a repeater to significantly increase the range of the search or display of coordinates. The repeater may be installed on a UAV (unmanned flying vehicle).
- Heavy duty metal housing searcher with protective glass on the display.
- The searcher is able to work with all beacons previous one family of digital beacons ROCKWELL PELENG.
* (with the line of sight and the directional antenna. )
Controls and indicators.
On the searcher located: top - miniUSB connector for charging the battery, button POWER, button MODE, antenna connector SMA-type, front - under durable protective glass two-digit super bright LED display and charging LED.
At the beacon Lite and Sens - miniUSB connector for charging and connecting an external GPS or controller NAZA (or WOOKONG), two LEDs - the indicator of work and control charging and antenna length approx. of 75 mm.
Functions, what using with the button on the searcher:
Long pressing the POWER - power on and power off the searcher.
Short press the POWER - switches to the next beacon, or if the derivation of the coordinates on the display active - stops this conclusion
Long pressing the MODE - enables / disables the repeater mode.
Short press the MODE - in "Beacon" mode starts the output of the coordinates on the display. In "Alarm" mode resets the alarm and reminder (extinguishes light and sound signals).
Long press both buttons at the same time - switches the system from the "Beacon" mode to the "Alarm" and back.
(Long press - press button more than 4 second).
Dimensions and weight.
Beacon  LongLife dimension 35 * 64 * 15 mm and weighs 21 grams (without batteries).
Beacon Sens and Mini  dimension 43 * 22 * 8 mm, weight 12 grams (with built-in rechargeable battery).
Beacon Light dimension 25 * 20 * 5 mm and weighs 3 grams
Searcher   dimension 90 * 50 * 25 mm (without antenna) 90 g weight.
All dimension without connector and antenna.
Characteristics.
The range of possible search is primarily determined by the conditions of propagation of radio waves through the local barriers and  the level of radio interference.
On with the line of sight and the directional antenna approx. 8 km.
On open area approx.  2.5 km.
In city - 800-1400 meter, completely through 1-2 the multi-storey building
The working frequency band of the device - 868 MHz
Beacon output power - 25 mW.
Current consumption searcher from computer USB port - up to 100 mA
Current consumption of the beacon, the average standby mode - 40 microampere
Work time beacon Sens and Mini in the "Beacon" mode - up to 2 months
Work time beacon Sens in "Alarm" mode - up to 14 days
Work time beacon Long Life - up to 2 years
Work time searcher in the "Alarm" mode - up to 1 days
Work time searcher in the "Beacon" mode - up to 8 hours
Что то нажал в настройках, типа эмулировать что то там.. теперь нули показывает в поле Lat/Lon, не знаю правильно ли это.
Подключу сегодня к ГПС, проверю.
Тут вопрос не задавали, будет ли работать маяк с ЛРС RLink http://fpv-community.ru/store/product/165-816-kanalnaia-rlink-lrs-sistema/ не будут ли они друг другу мешать?
У кого на каком расстоянии удавалось максимум отслеживать ЛА в которой установлен маяк?
Как мне нравится конкретика пользователей "что то нажал", "что то показывает" ))))))) Нули, это правильно, смотрите мануал.
Рлинк на 433 МГц, маяк на 868, мешать друг другу не должны, если Рлинк 2-й гармоникой не "пылит"
Планирую приобрести данный поисковый комплект, в связи с этим вопрос., Так получилось что уделяю FPV хобби, в основном холодные месяцы года ( в теплые другие увлечения). Как долго может работать аккум в маяке, например в -20 градусов?
Прошу прощения. Ответ найден на первой странице)))
Для работы на морозе лучше всего подойдёт маяк lBeacon LongLife, батареи которго лучше других работают при низких температурах.
 Есть ли техническая возможность "подружить" один из маячков данной поисковой системы,с автопилотом Аркбирд? Думаю,масса народу была бы очень благодарна,если что.
У Аркбирда вывод GPS данных в каком формате?
Добрался таки до настройки ПУ и коннекта его с прогой Bluetooth SPP PRO. Телефон нашел ПУ, удачно добавился в список устройств, имеется подключение, все кашерно. Прога Bluetooth GPS удачно работает с ПУ, все четко, а вот не получается законнектить прогу Bluetooth SPP PRO с ПУ! Она находит мой ПУ, видиет его RSSI, показывает его UUID, MAC.., нажимаю Connect, пытается подрубиться, НО гад выдает ошибку SPP Communication failure! :( Телефон перезагружал, другие приложения блютуз не запущены!! От не пруха!
Edited by lavalava
Попробуйте переустановить Bluetooth SPP Pro.
Не помогло :(
Нашел кучу прог под названием Bluetooth SPP от других разработчиков. Одну установил - блютус СПП Манагер, работает, подключается к ПУ, а что дальше делать х.з
Edited by lavalava
А дальше все по инструкции. Давайте команды, смотрите ответы - все в мануале прописано.
А что вы изначально хотели сделать при помощи Bluetooth Spp Pro?
Только лишь включать и отключать звук на данный момент..
Запросто! Никаких секретов, вот цитата из инструкции
" - команды, доступные только через Bluetooth
- звук, $*80-выкл, $*81-вкл"
Даете в терминале поисковому устройству строку $*80  - оно выключает звук, даете  $*81 - оно включает.
lavalava likes this
Проверил, другая прога работает тоже, просто нет возможности назначить кнопки в ней.
Какой GPS датчик(модуль), оптимальнее всего подобрать для маячка например Sens ? Или можно выбрать из нескольких вариантов?
Вполне неплохие модули на чипсете ublox neo 6 или 7
 Спасибо,я посмотрел.Сравнил.Сделал предварительные выводы.Серия Ублокс около 4 тысяч,округлённо если,то VK16E,на Ебае 15 баксов.Отличаются ли они как то функционально кардинально?Или разницы нет?
Чем вы посмотрели? Средняя цена на модули ublox 6/7 - 1-2 т.р.
Edited by KBV
И те, и другие, спутники ловят. Что до сравнения характеристик - так откуда мы можем знать, что для вас оптимальнее? Почитайте даташиты на модули, сравните нужные именно вам параметры.
Вообще говоря, тема выбора оптимального GPS приемника это оффтоп здесь. К маякам Сенс и Мини подходят 95% выпускаемых на сегодня GPS и GLONASS модулей, всех не перечислить.
 Получил сегодня на почте часть поисковой системы Роквелл.А именно только сам блок,с антеннкой.Маячки закажу позже,когда закончится финансовая недостаточность.Должна ж она когда то закончится.Надеждой живёт человек. Дома нашёлся и кабель,что бы заряжать,как раз с нужным разьёмом.Подоткнул к компу и к Роквеллу.На коробочке красным светом,горит маленький светодиодик,в левой части табло.И думается мне,а как оно выдаст,просигнализирует,что зарядка закончена? И ещё.Я читал отзывы.Когда сам взял в руки данное изделие и чуть потряс его,то согласился с мнением народа.Однако брякает в середине плата.Даже я бы сказал,погромыхивает.Ну,на функциональных возможностях это наверно не должно как то сказаться,но впечатление оставляет как бы по корректнее сказать.....   Как будто в руке дешёвая китайская игрушка,купленная в середине девяностых на рынке. ))
" ... Красный светодиод укажет на начавшийся процесс зарядки, по окончании он погаснет. ...." Это из инструкции, из раздела" Зарядка маяков и поискового устройства ".
Проблема люфта платы на некоторой части изделий нам известна и мы её решим в следующей ревизии конструктива.
