9 сообщений в этой теме
Вот такой вот занятный самолетик от RMRC с размахом более 2 метров стирает грани между хоббийными моделями и профессиональными БПЛА.
Specifications:
  • Wingspan: 2,060mm​
  • ​Wing Area: Approx. 4,900cm2
  • Length: 1,410mm​
  • Motor: RMRC Tiger Motor Brushless Outrunner AT3520-5, 800kv​
  • ​Propeller (sold separately): Recommend: 15x4E. Also can use 14x5.5MR, or similar.
  • ESC: RMRC Tiger Motor 80A ESC with switch mode BEC (T-Plug connector)
  • Servos: 3x 30g and 2x 17g Metal Gear Digital (does not include 2x servos for flaps)
  • Recommended Flap servos: HS-81/HS-85
  • Battery: Li-Po 4s 5,000mAH - 20,000mAH (Additional nose weight needed with smaller batteries)
  • ​Center of Gravity: 1/3 of wing from leading edge on the main spar
  • Approximate flight duration: 45 minutes to over an hour depending on configuration
  • Fuselage dimensions (Inside): L 66cm (26.5") x  W 15cm (6") x H 8cm (3") Maximum measurements​
  • *AUW - Bare PNP Version Weighs ~5.25lbs out of the box
​​RMRC's Setup for the Anaconda:
  • Stock PNP Electronics
  • 2x RMRC 5100 4s batteries wired in parallel
  • Eagle Tree Vector flight controller
  • Feiyu-Tech 3-Axis Gimbal with adapter
  • Nose mounted Pro-700N Camera
  • APC 15.5x4E Prop
  • ​HS-85 Servos for Flaps
Anaconda
1956667_814948628535056_5597547255417753
1402288_814948345201751_6396942947021168
10293711_814948481868404_907151433151986
А вот и посылка....
post-1-0-95121300-1428594557_thumb.jpgpost-1-0-05394900-1428594559_thumb.jpgpost-1-0-39968800-1428594560_thumb.jpgpost-1-0-08085600-1428594562_thumb.jpgpost-1-0-44398300-1428594563_thumb.jpgpost-1-0-04030700-1428594565_thumb.jpgpost-1-0-49480300-1428594566_thumb.jpgpost-1-0-36109400-1428594567_thumb.jpgpost-1-0-80200600-1428594568_thumb.jpg
post-1-0-39045500-1428594588_thumb.jpgpost-1-0-69158800-1428594589_thumb.jpgpost-1-0-87624800-1428594590_thumb.jpgpost-1-0-73372100-1428594591_thumb.jpgpost-1-0-96370900-1428594592_thumb.jpgpost-1-0-16728700-1428594594_thumb.jpg
Ждем отчета ! интересный аппарат!
Народ уже летает
На крайнем ролике - OSD такая или это графика для наглядности?
вероятнее всего это постобработка
Стопудов постобработка, но интересно, для какой ОСД есть такие приблуды?
думаю это вопрос не к OSD, а к программе постобработки, скормить ей лог можно любой OSD, а может тут вообще тупо вырезали с отдельного окна наземки куски приборной понели и наложили
Chipmaster понравилось это
Тоже смотрю в сторону Анаконды но не рискую пока кто нибудь не облетает и не даст вразумительный обзор самика.
Механизация крыла у него очень интересная помимо закрылков есть еще и предкрылки.!
Изменено пользователем andreilee666
