FlyGreen
Тема: Монитор 5" для FPV
Features:
• 5.0 inch HD Display with 350cd/m? Brightness
• Ideal for use with FPV
• No "Blue Screen" due to weak signal input
• 800 x 480 Resolution Display
• LED Backlight
• 16:9 Display Ratio
• 500:1 Contrast Ratio
• Supports video formats: NTSC M, PAL M, NTSC BG, PAL N,
NTSC DK, PAL DK, PAL 1, SECAM BG
• Anti-Glare Surface Treatment
• Foldable Plastic Screen Shroud for outdoor use
Specs:
Dimensions: 146 x 100 x 29mm
LCD Type: TFT LCD
Brightness: 350cd/m?
Resolution: 800 x 480 pixels
Display Ratio: 16:9
Backlight: LED
Viewing Angle: 70°/ 70° (L/R) 50°/ 70° (U/D)
Input Voltage: DC 6 ~ 18V
Input Signal: Video, Audio
Power Consumption: 6W
Working Temperature: -20°C ~ 60°C
Storage Temperature: -30°C ~ 70°C
Weight: 400g
Installation: 1/4"- 20 thread and VESA mounting socket (75mm)
Speaker: Built in, 1 Watt
Аналоговый вход видео-звук. В комплекте только монитор со шторками. Контакты  898I738789I
3500 рублей. Желательно в СПБ
